Hi all,
i have been working for three months to make a 40X2 communicate with a Teltonika TM2 GSM modem, using I2c interface. Picaxe is master, TM2 slave.
I am sure the TM2 works properly as I could set up a communication with the Picaxer through the UART
Unfortunately, as I was not aware of the specific TM2 I2c address (I even emailed the Teltonika CEO), I tried to communicate using the $00 address (global call). I was expecting the TM2 to reply.
It does not make sense, but I saw no signal on the data analyser at this specific address ($00). I tried with other addresses, casually, at least I saw the signal (address) sent by the master (and no response from the TM2 slave)
Your help is more than welcomed.
Laurent
Laurent
