I have the rev ed retailed Honeywell sensor and it is giving me up to 122% Humidity readings. Power is 3 x AA cells, actually giving 4.92V.
Here are my calcs, I'm sure they are OK but at full 10 bit ADC (1023) it will allow the sensor to indicate 135% RH. Any one else have this problem?
VOut = Vsupply ((0.0062 x SensorRH) + 0.16 )
Therefore VOut/Vsupply = (0.0062 x SensorRH) + 0.16 = ADC/1023
So, ADC/1023 = (0.0062 x SensorRH) + 0.16, dividing thru by 0.0062
SensorRH = (ADC/1023) x (1/0.0062) - (0.16/0.0062)
Therefore SensorRH = (ADC x 0.1576) - 25.80646
Or for code for the PicAxe :
63xSensorRH = 10 x ADC - 1665
The sensor seems right, at midday it was showing 66% humidity, (local airport 30 Kms away near the sea was showing 73% on the net).
This increased to 98% at dusk, then this morning it was 122%. Weather was foggy, so was definitely 100% RH.
I'm sure the sensor is Ok so I might need to limit the 100% reading in software. Just wondered if there are any similar experiences.
Dowmload cable is not connected, so it's not that skewing the number.
