I am trying to send serial data out the hardware HSPI SDO pin with no luck. I have a 20X2 PICAXE and using Program Editor version 5.3.6 and have some test code:
W0=4095
HSPISETUP spimode00,spifast
STRT:
HSPIOUT (B1,B0)
pause 1
goto STRT
Putting the scope probe on the SDO and CLK, all I see on my scope is what appears to be a PICAXE reset every 2.3 seconds. No serial data stream at all. The Basic Command document states that the SDI pin must be in the default state (whatever that means!), so I have pinned SDI to 0 volts and have also tried pinning SDI to +5 volts thru a 10K resistor, but still no data stream. Just the PICAXE reset every 2.3 seconds. The HSPI SDO pin is not connected to anything except my scope probe. What am I doing wrong.
From the Basic Command manual:
"Due to the internal operation of the microcontrollers SPI port, a hspiout
command will only function when the hspiin ‘input pin’ is in the expected
default state. If this pin is incorrect (e.g. high when it should be low), the hspiout
byte cannot be sent (as the microcontroller automatically detects an SPI error
condition). After 2.3 seconds of fault condition the PICAXE microcontroller will
automatically reset."
W0=4095
STRT:
HSPIOUT (B1,B0)
pause 1
goto STRT
