I have finally succeded after several hours of trying almost every thing else but what worked in geting my computer to communicate using hyperterminal with the 40x2 on the hser port.
Since I was also using the serial download link to get information back while testing I then tried to swap the usb to ttl interfaces from one to the other to see if the data streams would work through the other computer interface.
To my amazement it worked just by lifting the cables and swaping them.
I say I am amazed because with no diferences between the interfaces they would work on the ser link but on the hser link the mode was set to invert both in and out. This raises the question in my mind "WHY are the default hserand the ser ports different?" i.e. I would assume (since invert was not fully available in earlier release) that the inverted hser mode %111 is the exception - not thedefault but if I don't invert then I cannot read the data from the hser port but it works on the ser download port with no configuration at all.
As I say - I have it working - it took a while to fathom it out - but I am curious why?
Bert
Bert
