HPWM current capacity
#1
I have accidentally shorted picaxe outputs to ground in the past and no damage was done but I got a new 20X2 and accidentally touched an active HPWM output to ground with a scope probe ground clip and it appears pin B.4 has shorted to V+ and 0V internally.
What is the current capacity for HPWM outputs?
#2
My understanding is it is exactly the same as for any other I/O pins; so that would normally be 20mA, 25mA maximum.
It might be worth testing a short TOGGLE B.4 loop to see if the pin is still working if you haven't already..
