HPWM can only drive a single motor. The routing to each of ABCD is either the PWM signal, its inverse, fixed high or low.
The 14M has only a single PWM channel which can either be used as for classic PWM using a single output line, or through the ABCD lines.
When two PWM signals are available ( 28X etc ) I believe they are the same frequency, but have independent duty cycles, so the speed of two motors is entirely independent of each other.
Both motors on a vehicle platform would normally be the same so using the same frequency should not cause a problem.
Edited by - hippy on 04/07/2007 14:11:03
