donrecardo
Q. How tough is a Picaxe chip ?
A. Tougher than I would have believed
I wanted to build a circuit that required a Pic16F1827 and I don't have one ,
but I remembered reading that the 18M2 is based on that or a similar chip.
The circuit was to measure and the voltage on a car battery and display it
on a 4 digit common cathode display . (http://embedded-lab.com/blog/?p=3096 )
As I had 2 18M2 chips I figured I would lose the built in program and use it as a
straight 16F1827 . I built the circuit and programmed the chip and it sort of worked .
It showed a reading on the display but the reading wasn't telling the truth.
I was sat thinking what might be wrong for a couple of minutes or more when I happened
to touch the Picaxe chip and it burned off my fingerprint from the tip of my finger.
I switched off and had a poke around ( after it had cooled down)
The circuit takes an input voltage of up to 16.9V and feeds an ADC input via a voltage
divider . I also use this input to feed a 5v regulator to run the picaxe chip.
Sadly I had connected the picaxe to the input rather than the output of the regulator
so I was powering the the picaxe with 13.8v ( for more than 2 minutes )
I corrected my mistake . took out the fried chip and replaced it with a new one which I
had programmed . with the chip powered with 5v now as it should be it worked fine .
Just out of interest , I swapped the chip back to the one that was well fried and , you guessed it.
It works just fine . It had taken an over voltage of 13.8v for more than 2 minutes and it still works
Thats what I call a tough chip
Don
Don
