On older versions of PICAXE VSM the AXE033 Serial LCD model defaults to T2400 polarity baud rate, whereas a real life part defaults to N2400.
Fortunately is it very easy to invert the RXD pin on the model so that it will now work with a N2400 polarity signal.
To do this:
1) Right click over the 'AXE033 Serial LCD' model and click 'Edit Properties'.
2) Check the 'Edit all properties as text' box
3) Add this new text on a new line
{INVERT=RXD}
4) Click OK
The RXD pin will now 'invert' the signal, and hence work at the N2400 baud rate instead of the T2400 baud rate.
To do this:
{INVERT=RXD}
4) Click OK
