Follow srnet's suggestion; plug it in preferably with a current-limited supply or batteries and check current with a brief power-up.
If only a few mA try programming something simple and quick. And use Thumb-ometer to test heating. And use a nose to detect for tex's smoke.
As Westy says, there are occasions when a section of the PIC hardware (peripheral) may have failed.
I had a cak-handed moment with a dsPIC once and a single ADC channel had died. I wasted loads of time wondering why my circuit was giving daft results.
Some people mark an apparently uC as 'potentially iffy' and save it for specific work.
Some people run a diagnostic programme to see if any of the peripherals are playing up.
I usually bin it as I am a lazy git and don't want to run the risk that abuse may have partially upset something.
You may be alright and ideally you will two PICAXEs so you can test side-by-side.
(Buying singly during the learning curve is a mistake).
Sooner or later you will have to try it out. Make it sooner and put yourself out of your misery
Treble check all your connections and supply, Keep it simple and try it.
