Hello
I have been watching some videos and reading information on how to calibrate the MQ135 to be able to measure CO2 in PPM. Currently I already have the formula to calculate it, which is: 5.1839*pow(Rs/R0, -0.348)
Where:
R0 = 82 //initial MQ135 reading, found from the average of 100 readings
Rs = 1000*((5-Voltage)/Voltage)
Voltaje = MQ135_ADC*(5/255) //255 is the maximum value of the variable and MQ135_ADC is the sensor reading
I have some problems, which are:
1. All the information that I have found is for arduino and, what I have seen, is when they use the MQ135, the initial measurements, you get hundreds or thousands, while when I do the ADC reading, I get an average of 87. Could someone tell me why this is? I did the datasheet, the thing about having the MQ connected for 24 hours, so I don't think it's something like that. If I do my calculation with that value, the amount of CO2 I get from the calculation (at least in a spreadsheet like Excel) is 0.5132, which is clearly a very low value for CO2 PPM.
2. I don't know how to calculate numbers with a decimal point and negative exponentiation, could you help me? I am using the PICAXE 20M2
Thanks in advance
Where:
Thanks in advance
