I am using an 18X with an I2C EEPROM. I have the circuit working fine. I read voltage data into the 18X ADC pin and write data to the EEPROM. I read the daae from the EEPROM and verify it works using SERTXD. I received a tip that CoolTerm can be used for receiving data via the serial port and saving it to a text file. I am connecting to the 18X via the AXE027 USB cable. Has anyone used this software or similar software? If so does anyone have sample code I can try to test the connection? I have been struggling to understand how the software works. Also, not sure if I can read via the sertxd command and serout pin. DO I need to set up another connection to the computer via an output pin and the serout command?
