how i got Linaxepad to work in ubuntu 14.04
xfred
Greetings,
i have now installed successfully, linaxepad on two seperate computers, one dual core and one quadcore 64bit running Kubuntu 14.04
I found the pdf's outdated, and alot of websites outdated...and lots of errors... however, here goes...
Download --- LinAXEpad for Linux (v1.5.0 for x386 with GTK2.8+) (from this site to a folder)
extract in folder (right click -extract-extract here)
you should get 4 folders and one file
compiler_linux
datasheets
linaxepad libs
syntax
linaxepad executable
now, get into root
zx80@zx80-desktop:~/Desktop/linaxepad$ su -
Password:
root@zx80-desktop:~#
do the following:
(updates)
sudo apt-get update
(tells the GTK info)
dpkg -l libgtk* | grep -e '^i' | grep -e 'libgtk-*[0-9]'
(tells library location & memory addresss)
ldd LinAXEpad
(installs librarys)
sudo apt-get install libgtk2.0-0:i386 libcairo2:i386 libpango1.0-0:i386 libgdk-pixbuf2.0-0:i386 libstdc++6:i386
(final update)
sudo apt-get update
now go into your directory where linaxepad is
right click on the file LinAXEpad - actions - run in konsole
you can also double click on the file, it should now work
if you get the
(unresolvable error)
(LinAXEpad:3838): Gtk-WARNING **: Unable to locate theme engine in module_path: "oxygen-gtk",
Don't worry about this error... it's meaningless (more or less).
I wish you all good luck!
xfred
Hi xfred,
It also works for Debian Jessie. Instructions (in french, but mostly just a list of commands) to get the usb cable working can be found here http://gregblog85000.free.fr/?p=619
I had no errors.
Cheers!
EDIT: If you use cut and paste, make sure your text editor doesn't change the punctuation!
Back
