how do i program to count a number of pulses then give an output
peter howarth
I would like to program a picaxe to count,say 10 pulses, be it a second long,a second in between pulses, then once say 10 pulses are counted, then give or change a status on an output, then have the picaxe continue on with other stuff,
also is it possible to program a picaxe to have an output flash a led whilst ever power is applied,, as well as the picaxe perform its other programmed (sequential) functions..
This program accomplishes the first--you can run it in the simulator.
#picaxe 08M2
symbol bPinVal = bit0
symbol pulseCount = b1
symbol pPulsePin = pinC.3
symbol pLED1 = C.1
  if bPinVal <> pPulsePin then
    bPinVal = pPulsePin
    if bPinVal = 1 then
      inc pulseCount
      if pulseCount = 10 then
        toggle pLED1 ' on for 10 pulses, off for 10 pulses
        pulseCount = 0
  ' now do other stuff
The following does the same but also toggles pin C.0 every second (using the "time" variable available on M2 PICAXEs).
#picaxe 08M2
symbol wSeconds = w13
symbol pLED1 = C.1
symbol pLED0 = C.0
wSeconds = 0
time = 0
  if wSeconds <> time then
    wSeconds = time
    toggle pLED0 ' toggle every second
    bPinVal = pPulsePin
    if bPinVal = 1 then
      inc pulseCount
        pulseCount = 0
This also will run in the simulator, but note that because of the slow speed of the simulation, the toggling will not strictly occur every second. It will on a real chip (unless your other code takes so long to execute that some seconds are missed).
I would do the pulse counting this way -
#Picaxe 08M2
Symbol PIN_IN  = pinC.3
Symbol LED_OUT = C.2
Symbol counter = b0
Low LED_OUT
For counter = 1 To 10
  Gosub WaitForPulse
Next
High LED_OUT
End
WaitForPulse:
  Do : Loop While PIN_IN = 1
  Do : Loop Until PIN_IN = 1
Multi-tasking can be used to have a 'RUN' LED flash at the same time -
#Picaxe 08M2
Symbol RUN_OUT = C.1
Symbol counter = b0
Start0:
  Low LED_OUT
    Gosub WaitForPulse
  Next
  High LED_OUT
  End
WaitForPulse:
Start1:
    Toggle RUN_OUT
    Pause 1000
