I was recently introduced to this
http://www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXywxyt.pdf
and thought of manie
It's designed for automotive use and as such is pretty much indestructible
It's rated at 5.5v to 36v with a current of 9A and Ron of 40mOhm.
I've put it through some tough tests and it's still living.
Switching inductive load 300mH @ 1A NO PROTECTION.
It's internal clamp clamps at 50v less than Vcc. Survived no problem but I'd suggest fitting a clamp diode anyway for inductive loads.
Switching a dead short from 36v. (no heatsink)
Internal current limit limits to about 18A.
Gets hot then thermally shuts down once case reaches ~130oC.
Also has significant ESD protection to 4kV.
The only downside is slow on/off times of 10's of microseconds so you won't be making any high efficiency switchers with it but at least it won't smoke if you try.
So far, the only way to kill it is to make Vcc > ~40v.
A challenge for you manie!
