Without going into too many details about the wireless side of things, I want to obtain the highest possible data rate using audio modulation techniques. This is pretty straight forward using FSK or Manchester encoding over a single audio channel (of say, 50Hz-10Khz bandwidth) but how best to make use of a ‘stereo’ configuration? You could easily get twice the data rate by using independent microcontrollers and modems on each channel but could there be more direct way to use stereo to obtain higher data rates? Please let me know if you have any ideas.
