hi help me pls picaxe kam ni kar raha main kya karun?????
Weird Al
hi merko koi help karo mera picaxe software kam hi nahi karre main kya karun vo software apne ap 15% pe download karna ruk jata hai help karo pls karo help
I'm going to take a stab and guess your problem is that your download is failing to complete and you are only getting part of the download file needed to install the Programming Editor.
If your ISP has a download limit you will need to find somewhere else to download from, a friend, a scool, an internet cafe or purchase the software on CD.
If it is your PC which is the problem then check all your settings, however downloads can fail for a variety of reasons which are neither the fault of those providing the file or those trying to download it. You can try downloading off-peak when local traffic is light ( but it could be busy elsewhere in the world ) and try using a file download manager.
If you have registered to download the software then obtaining it from someone who has also registered would not be an unreasonable step to take. The file you need is BAS805.EXE.
