Digisapien
Well when I was having.the problem with a switch not reacting fast enough ive dicovered the interupt command sequence and was wondering if somoene could give me a simple example using it. Say
With 20m2 chip a button and one led. I would appreciate it.as the syntax example would help. Confused on the way I designate the 8 bit to pin %00000000,%00000001
