Help with ReadTemp12 maths
#1
Guys,
I have gone over previous forum posts and must admit that i am pretty lost when it comes to the maths that is involved with READTEMP12 (probably why i had always used plain old READTEMP before.
I have a routine that Hippy previously posted that is working to format and displat the READTEMP12 routine (on a 40x1) to an LCD panel and this is working well.
However i would like to be able to test within my code for more granular than 1 degree increments and am unsure how to do this
Currently my code goes something like
If AverageBackDoorTemperature >= 22 then Goto Overheat
What i would like to do is be more granular than 1 degree increments.
I am working in Celsius and store the ReadTEMP12 value in a word variable.
Can anyone provide some code i can try to follow to compare on 1/2 (or 1/4 degree numbers) presumably if these were left as binary this would be easiest ?
Craig
#3
Hippy has some good code that works to 1/2,1/4,1/8 etc but personally I prefer to work in 0.1s.
Readtemp12 returns the celcius value X16.
Hence /16 to get to deg C.
However, if you want the extra decimal place, then X10 first.
eg (I've used many variables to show working)
readtemp12 pin,w0
w1=w0*10 '(temp X 160)
w2=w1/16 '(temp X 10)
b0=w2/10 'integer part
b1=w2//10 'decimal part
sertout pin,baud,(#b0,".",#b1,$D3,"C")
The $D3 is the code needed to display degree sign for MY LCD display. It may be different for other displays and I can't remember the value for the terminal.
Edited by - beaniebots on 14/08/2007 08:29:02
#4
Hey BB,
Thanks for the quick response. Once i get the temp Value x10 (as per step 2), i do not want to output to screen but simply test and action - so would it be valid to say something like
if W1 > 215 goto overheat 'this is the equivalent of 21.5 degrees ?
regards
Craig
#5
If you only want a threshhold, then don't do any maths at all.
Keeping with the variables used in my example:-
if w0 > 344 then...
is equivalent to:-
if w0 > 21.5C then...
Or, for easier reading (but reduced resolution) you could use:-
if w2 > 215 then...
is equivalent to:-
if w2 > 21.5C then...
Note, I had a variable typo in the earlier reply which is now corrected.
Edited by - beaniebots on 14/08/2007 09:39:45
#8
Something about a sign bit in Bit 7 i believe. One of the brains trust will know though, or you can do a search on ReadTemp12 - there are heaps of posts (most answered by Hippy, Stan or BB
Craig
