Hi folks
Have not been on here in a while and trying to get my Micro-controller brain restarted.
I am building a brass annealing machine. I am using the Picaxe020 to control the stepper motor in the project. I am using 12VDC secondary voltage for the L293D and the ULN2803A. Yes both chips are in at the same time.
I am trying to use the left over outputs via the ULN2803A. (b0-b3). The output goes hi but I only see 0.5 volts. The outputs, b0,b1, go to a voltage divider which then drives a TIP122. Voltage divider drops 12VDC to 5VDC. TIP122 circuit works, it has been tested by itself.
EDIT: the TIP122s drive 24vdc solenoid valves
So any idea why I am only getting 0.5 volts???
Thanks guys ( I know that I am missing something, just can't put my finger on it)
