stocky6409
Hi All,
Just looking for suggestions/ideas in case others have already done this.
I have need to produce a minimum of 4, more likely 8 and up to a possible 16 INDEPENDANT PWM/analogue outputs for a project. Resolution is *not* of high importance. My current thinking is to use Dallas DS1050 5 Bit PWM controllers - that will give me 8 outputs.
Update frequency for the outputs will be measured in minutes so speed is also not of the essence.
Prob have to use 28 series picaxe - not that I need the IO but have to respond to serial input at anytime while allowing program execution to continue.
Technical, any light at the end of the tunnel for an upgrade of serial routines on the 18 series?
Cheers
Stocky
Cheers
Stocky
