I built another breadboard this evening to start workinhg on the 80x quiz project, and I guess I don't understand input pins quite right. The following program works fine on everthing except input. I'm using 80X pins, 15-18. I'm attempting to tie the pin to ground to trigger switches 1,0,7,8.
Can someone take a look at this and tell me what I'm not understanding?
' Quiz Controller For 80x
' By Jeff Ledger
let pins = 0
'power on indication
high 4
high 5
high 0
high 1
high 2
high 3
pause 2000
main2:
low 0
low 1
low 2
low 3
quizloop:
if pin1=1 then seat1
if pin0=1 then seat2
if pin7=1 then seat3
if pin6=1 then seat4
goto quizloop
seat1:
high 0
pause 5000
goto main2
seat2:
high 1
pause 5000
goto main2
seat3:
high 2
pause 5000
goto main2
seat4:
high 3
pause 5000
goto main2
goto main:
Thanks!
Jeff
' By Jeff Ledger
let pins = 0
high 4
high 5
high 0
high 1
high 2
high 3
pause 2000
main2:
low 0
low 1
low 2
low 3
quizloop:
goto quizloop
seat1:
high 0
pause 5000
goto main2
seat2:
high 1
pause 5000
goto main2
seat3:
high 2
pause 5000
goto main2
seat4:
high 3
pause 5000
goto main2
goto main:
Thanks!
Jeff
