Hi All
I'm messing around with magnets for my project pinball project. I'm using Bally/Williams 20 9247 magnets off a 50VDC Supply. These measure at about 5.6ohms. Now when I fire one up I'm pulling about 8.7amps which is right according to Mr Ohms and a bit of inductive reactance of the metal core.
My problem is I could have 4 magnets active at once , which means I would need a 40amp supply, this is not good...
I was wondering if i could use pulse width modulation to run the magnets? This could reduce the power required and help cool the magnets. But I don't know if this would weaken the magnet field too much.
Like a solenoid, I would need an initial surge of full power 100%, then cut the power down to say 60%
I was going to use a 08m2 to run the transistors that will turn on the magnet.
So if anyone could lead me in the right direction with some nice code,( with some noob notes ) that would be wonderful.
Thank you
Thank you
