Hi All,
I've been lurking for some time and just finished soldering my PICAXE Experimenter board, but am stuck at the 2nd hurdle.
Am I being typically thick, or is the only way to use the soldered components on the PCB by putting the PIC in the breadboard? Or is there a way to use the LED's (for example) by keeping the chip in the IC socket?
If it's supposed to work, then I've messed up the soldering and I'll get out my trusty circuit tester!
Anyway, thanks in advance!
