buzzlightyear
I'm trying to come up with a pulsetrain device, using the 08m2, details in the comments in the code, but if anything is unclear let me know!
The pulses are only output once the input detects a rising edge, the input pulse is of unknown and changeable duration, and if a new input is detected the output pulse sequence is to restart.
The spaces between the output pulses will be in the milliseconds range (lets say 5-100ms variable, for now) the individual pulse length will be around 5ms, I want to be able to specify (by way of 3 pots) the number of pulses output, the rate of the pulses for example every 10ms, and the spread which will allow the rate to be non linear, for example 1-1--1---1----1-----1 or 1-----1----1---1--1 etc
Not quite sure how to implement all this, so any help is welcomed, thanks
symbol Trig = pinC.3
symbol PulseRate = b0 'Pot connected to pin 1
symbol PulseAmount = b1 'Pot connected to pin 2
symbol Spread = b2 'Pot connected to pin 4
readadc 1, PulseRate 'this is the rate of the pulses
readadc 2, PulseAmount 'this is the number of pulses from 2 to 8
readadc 4, Spread 'this is the addition of delay between each individual pulse
if Trig = 1 then 'on rising edge of input pulse in C.3, C.0 to output pulses according to the pot settings
'if while a pulse sequence is active a new input pulse arrives then restart the pulse sequence,
'if no input pulse then set C.0 to low, loop around main.
