'Example for computer control of an LED connected to pin B.0 of a PICAXE
#picaxe 18m2
symbol led = b.0
serrxd b0
if b0 = "1" then
high led
elseif b0 = "0" then
low led
end if
The AXE027 is standard when in normal use - do not select NONSTANDARDin serial terminal,
i selected nonstandard axe027only and what baud rate should i select?
You actually hit the nail on the head Hippy. Unfortunately you mentioned what the message meant and not what it said.It doesn't seem that unclear to me; select baud rate, 300, 600, etc to 76800 or a non-standard baud rate (AXE027 only).
