Minifig666
I have recently dismantled a computer and got a Maxtor 40GB HDD out of it. The spindle motor in the middle has 4 pins coming from the left they are labelled as this from top to bottom; MTR-C, MTR-B, MTR-A, CT. I'm guessing that's coil 3, 2, 1, and ground.
When the HDD is plugged in to a power supply it spins then stops then spins up again. This is obliviously not very useful.
How would you go about ruining this with a PICAXE? I know it will need power transistors and that sort of thing but I am a bit lost with the code. I wish to use it with an 08-M, using the input to start it and stop it and the outputs to run the transistor circuit. Can anyone give me an example of code? Thanks in advance
