reynoldsw87
Afternoon all,
I have been given some HC-SR04 to use on a robotics project. The robot is being designed for primary students so I will be using the flowchart software and not basic.
Is it possible to use the SR04 with PE Flowchart software or not? Is the ultra command transferable or would I have to create a sub-routine to get it to work?
Does the sensor need to be wired up a special way?
Am I creating a headache that is not worth it and I should just bite the bullet and get some SRF05's from China?
Thank you in advance.
Will
Will
