PhilHornby
They're definitely duplex, rather than simplex - but whether they're full or half duplex I don't know ... I haven't had need to pass data simultaneously in both directions.Do the units work as simplex or have they got to be used half duplex?
(Definitions: http://www.iec-usa.com/Browse05/DTHFDUP.html)
Yes you can do that. The only real difference is that the HC-12 parcels-up the data into packets - so the gaps between the characters will be different. Also the HC-12 presumably has a finite buffer size (and there's no flow-control), so there would come a point where you have to stop sending data, and wait for the HC-12 to deal with it. (I seem to recall that this varies with the mode the HC-12 is in).him as well said:Don't suppose its possible to simulate any of this?, can two picaxe communicate serially hardwired, the info seems to imply that the HC-12 just replaces a serial link?
