As some of you might have seen, I've been using a bit banged SPI bus to control a DS1802.
The DS1802 can also be used by grounding push button controls.
When I use the SPI bus to change the uPot, I get an inherent click through the speakers. However, when I use the push button controls directly (using a resistor and length of wire soldered to it to ground) I get no click, and the transition is smooth.
Now, the picaxe is directly attached to the DS1802 with a RST pin, Clock pulse pin and Data pin. There are also 3k pull down resistors on the SPI pins of the DS1802 and there are 2x DS1802 being controlled.
Now the silly thing I think I've done is to have connected the picaxe to the DS1802 without any kind of a resistance between.
Any ideas?
Any ideas?
