I need someone who knows, to have a look at this because I want it to work and its affecting my logic.
I am using four of the same MOSFETs to drive a motor in an H bridge, the MOSFETS are driven of an L293D. Most tell me that I should use two P type and two N type but according to others, that is not always the case.
The MOSFET is a P60N06 controlling 24 volts. I was considering running a pair in parallel rather than just having individuals (so 8 in total)
By the way there is a minimal lag in the program so that there one side of the motor is positve and the ther is negative or in an instant they might both be negative, but never both positive because apparently thats no a good thing
The L293D seems to be either on or off and changes state quickly, so minimal heat, is this the case.
I tried to work out a way to fit the suppresion diode, but it has to work in both directions.
By the way,power in from the top, out bottom.
The part you can't see is that the voltage to the MOSFETS ( not the gate charge) is Pulse Modulated to contol motor speed, so the H bridge MOSFETs don't need to pulse, they just need to act like an L293D on steriods.
I want to run 24 volts up to perhaps max 5 amps ( I know stalled or starting it will be higher for a little bit), the motors are 250 watt geared motors and if they go above 5 amps then thats no where near normal.
Enough rambling, can you have a look, have a comment, have no one around to ask or I would.
There is a box of virtual chocolate bars in it hippy, but sharing is manners my mum said.
Thank you.
Thank you.
