Hello,
I have a problem with my development starter pack. When I select PICAXE/Program
I get the message "hardware not found on /dev/ttyUSB0". No matter which port on
the computer the USB cable is in.
1. I have assembled the bord as shown in the attached picture: The cut-out in
the MP is up. The red wire is +. The USB-cable can be attached to any USB on
the computer. The green light is on.
2. I have downloaded the editor
3. I have entered 99-axe027.rules as follows:
# /etc/udev/rules.d/99-axe027.rules
# contains axe027 udev ryle to patch default
# FTDI product id to AXE027 product id (0xbd90)
ATTR{idProduct}=="bd90", ATTR{idVendor}=="0403", RUN+="/sbin/modprobe -q
ftdi_sio product=0xbd90 vendor=0x0403"
4. I can run a serial loop back test with the USB-cable in any port on the
computer
5 I cannot do a serial port test because I cannot find Show Port Help Tools
under View/Options
6. Under View/Options I have selected ModeICAXE-18M2 and
Port: /dev/ttyUSB0. The 3 buttons AXE027 modprobe, USB Setup and USB Help
produce no results. When I press the button Firmware under Port I get the same
error message as above.
7. Under /dev I find ttyUSB0
8. I am running Linux
I have run out of ideas. Can anyone help?
Best regards
Torben
PS! I cannot attach the picture - it is too large.
computer
under View/Options
Best regards
Torben
