Alright it's time for a newbie question. I'm working on my first board (08M2), and I keep getting the classic "Hardware not found on COM #".
I'm using the AXE027 cable with the AXE029 adapter kit. (I've got the IN wired to C.5 [serial in], jumper set to 01, and the 01 wired to C.0. GND is connected to -)
I've gone through the troubleshooting to determine that I'm using the proper COM port (device manager + scan for USB under COM tools).
I've done the troubleshooting where you test the IN against the V0, by wiring it to a LED (and 330ohm resistor), and it behaves as normal (LED lights up when it should, and turns off when it shouldn't)
So where do I go from here? If needed I can post a video of the above, just to make sure everything is doing what I think it is, as well as piecing together the board so I know it's correct as well (it doesn't take but a minute).
