Hall effect and interupt.
shamu
Hi all.
I am in the process of making a POV display, a rotating Hall effect switch triggers the sequence when it passes by a magnet.
The code checks the state of the Hall input using an 'If' statement at the start of a loop, the problem is that unless the Hall switch is triggered at the same instant as the 'If' statement is executed then the sequence doesn't start, can an interupt be used in some way?
Thanks.
[B]main:
#picaxe 40X2
#no_data
let dirsA = %11111111  ' Set port A as all outputs.
let dirsB = %11111111  ' Set port B as all outputs.
let dirsD = %11111111  ' Set port D as all outputs.
SYMBOL Delay = 300
  high C.1 'Blue when high.
  low C.5 'Red when high.
start:
 'let outpinsD = %11111111 'Turns all port D pins off
 'let outpinsA = %11111111 'Turns all port D pins off
If pinc.2=0 Then 'Responds to a Hall Effect switch when connected to pin 17
    let outpinsD =%11111111
  ' The 2 of 12
  '         128 64 32 16 8 4 2 1
  let outpinsA =%10011100
  let outpinsA =%10111100
  let outpinsA =%10111110
  let outpinsA =%01111110
  let outpinsA =%01111010
  let outpinsA =%11100010
  let outpinsA =%10001110
  let outpinsA =%11111110
  ' This is the gap before 1.
  let outpinsA =%11111111
   ' 1 for one o'clock
  let outpinsA =%00001111
  let outpinsA =%00011111
  let outpinsA =%11001111
  let outpinsA =%11100111
  let outpinsA =%11110011
  let outpinsA =%11111010
  let outpinsA =%11111001
  let outpinsA =%11111011
' This is the gap before 2.
  ' 2 for two o'clock.
  let outpinsA =%10001111
  let outpinsA =%10111111
  let outpinsA =%00111111
  let outpinsA =%11011111
  let outpinsA =%11101111
  let outpinsA =%11110111
  let outpinsA =%11111101
Else
  low C.1 'Blue when high.
  high C.5 'Red when high.
  let outpinsB =%11111111
  let outpinsD =%00000000
End If
goto start
[/B]
Buzby
You need to wait for the trigger to change state :
Do
	' Waiting for pin to go High
	loop until pinc.2=1
	' Waiting for pin to go Low
	loop until pinc.2=0
	' Put main code here
Loop
