Cut down - balloon release
Cut Down
Just tested the mod to allow a remote cut down (balloon release) of HABAXE.
Remotely operated cut downs don’t seem popular in the UK, which is odd considering the obvious safety benefit of being able to terminate a flight if the balloon drifts where it should not.
One reason seems to be a belief that the transmission of a cut down signal is not allowed, even for a radio amateur. Ofcom seem ambivalent on the issue, and for it to be illegal the receiver on the airborne balloon would need to be deemed part of the ‘amateur radio station’. This seems completely untenable as no license is required to own or use an amateur radio receiver in the first place, so how can a receiver also be considered part of an ‘amateur radio station’ ?
However, whilst the use of an amateur radio license would be needed to if you wanted to use a high power amplifier to send a cut down signal say 1000km (needs about 5W ERP), the RFM22 can be used on its own over shorter distances.
Transmissions of 10mW are licence exempt, and this would have a range of about 15km, ground station to balloon. RC control in the 458Mhz band at 100mW is allowed in the UK, and this would have a range of about 40km.
The RFM22 can easily switch between transmitting on one frequency, license exempt at 434mhz say, but then listen on an amateur radio frequency or the RC control frequency of 458Mhz. Similarly the ground station can easily switch between downlink and uplink frequencies.
Implementing a cut down is actually very simple with a small MOSFET and a Lipo.
You can get ready made nichrome wires, a short length of nichrome with two bits of copper wire welded on, these are ideal for melting a bit of nylon cord.
I measured the current it took to melt a bit of dyneema, its stronger than nylon and has a lower melting point. The cord cut within 10 seconds at a current of 800mA.
I next measured the short circuit current of a small 70mah Lipo weighing 2.2g, it was 6A with the protection circuit removed, that ought to be plenty.
A DMP1045 SOT23 MOSFET will handle 5.5A, has a rated forward resistance of 31mR, and a gate source threshold voltage of 0.55V.
So all we need to do is arrange for the ground station telemetry receiver (see picture) to transmit a command packet at the appropriate time. In the case of HABAXE it goes into listen mode just after the FSK RTTY and telemetry packets are transmitted, at this time just press the button on the ground station receiver, and the cut down packet is sent.
When the cut down command is received, the MOSFET is turned on, the nichrome wire goes red hot and the dyneema cord breaks within about half a second. See the arrangement in the picture, the two black wires connect to solder pins, and you cn just see the nichrome wire wrapped around the blue suspension cord.
Cut Down
