Technoman
As many articles are relating code generation with ChatGPT (OpenAI), I gave a try.
I supplied the following description :
"basic code for a light activated switch Picaxe 08M2 240V SSR connected to C.2 LDR connected to C.1 hysteresis "
Generated code :
The result is not too bad. Even after slightly modifying the demand, it was not able to setup constants and use variables instead. Also an arbitrary value exceed 8 bits (threshold).
Generated code :
' Declare variables
dim threshold as word ' threshold value for LDR
dim hysteresis as word ' hysteresis value
' Set threshold and hysteresis values
threshold = 500
hysteresis = 50
' Read the value of the LDR
readadc C.1, b0
' Check if the LDR value is above the threshold + hysteresis
if b0 > threshold + hysteresis then
high C.2 ' turn on the SSR
elseif b0 < threshold - hysteresis then
low C.2 ' turn off the SSR
pause 500 ' wait for 500 milliseconds before checking again
goto main ' loop back to the start
