jedynakiewicz
I need to switch a number of outputs through a driver chip; normally I would use the ubiquitous ULN2803A but in this case I need to switch the high side. Fortunately, before they became discontinued, I bought a number of UDN2981A chips. These are really the high-side switching equivalent of the ULN2803A and have proved to very useful. The problem is that they do not quite have the same current rating and I am just getting a bit marginal at 400mA. They are specified for 500mA but 350mA is recommended deeper in the graphs within the datasheet (http://www.rapidonline.com/pdf/82-2202.pdf). I recall Hippy proposing piggy-backing ULN2803A chips in order to increase the output; also ganging up two or more lines within the chip is possible.
Do any experts foresee any problems in ganging up the outputs of the UDN2981A chips? I see no reason why I shouldn't, but it would be helpful to know if I am missing something before I waste a scarce resource and before I have to reach for discrete PNP power transistors or MOSFETs.
I would very much value your opinions and observations.
