There have been several previous threads on this forum about low-cost scopes. As far as I can see it, the conlusions are that you basically have three choices:
- (ab-)using your computer's sound card or hacking a device with display like the gameboy. The main issues are it is low bandwidth (audio, i.e. 20 kHz at best), audio cards are AC coupled (so you won't see the absolute levels), triggering etc. tends to be unstable, and you risk your $$$ computer are gameboy if you ever accidentally apply more than a few volts to the input. Overall, nice as a toy but not very useful for true work.
- professional, standalone scope, e.g. low-end Tektronix or other manufacturer. The upside is that this is a highly usable solution. Bandwidth nowadays starts around 50 MHz. I'd go for a digital sampling scope, since it has many advantages over traditional (analog) scopes, last but not least the possibility toe see what happened BEFORE the trigger, and to record longer waveforms. The major downside is price - with few exceptions it's above US$1000 (even used ones on ebay if they are in good condition).
- PC based scope: uses the PC for the main processing tasks and the display, so potentially much cheaper than a comparable standalone unit. I recently got myself a Velleman PCSU1000 that is basic but quite sufficient for my home lab (60 MHz bandwidth and 2 channel + trigger means you can even easily look at the clock signal of an overlcocked Picaxe). Cost around US$300 if you shop around a bit, and includes 2 probes. Attached to the USB port and doesn't even need a separate power supply. A more basic (1 channel, 12 MHz, parallel port) version can be had for little over $100. Picotech.com is another good vendor (bigger selection but tends to be quite a bit more expensive). Virtually all of those scopes double as a decent spectrum analyzer, very useful (decent standalone sampling scopes can do that, too).
Wolfgang
Edited by - womai on 30/04/2007 19:41:15
