I would "Widlarize" it. This term is coined after legendary IC designer Bob Widlar from National Semi.
A description by Bob Pease (another legendary designer also from National Semi) best describes the process:
"But there were times when Bob would discover he had wasted a day or two, just because one bad part had screwed up his circuit. He would bring this bad part -- a capacitor, a pot, a transistor, an IC, or whatever -- over to the vise and lay it on the anvil part. Then he would calmly, methodically beat it with a hammer until the smallest remaining part was indistinguishable from the dust on the floor. Then he would go back to work and get the right answer. He explained that it makes you feel much better if you do this, and, you know that bad part will never come around again and goof you up. He was right."
