I have small program (607 bytes) that I want to post on the FORUM. It is heavily commented and exceeds the limit allowed. What is the best/preferred way to post it??? Thank you, JimS
If it is too large to insert into the body of a post, then try adding as an attachment - particularly it it is going to be posted in the finished projects area.
You can also compress the file size a bit by putting into a .zip file.
If however you are trying to attach seeking help to resolve an issue then try to reduce the size to something that can be posted within a post and still demonstrates the problem/aspect with which you seek help.
To add as an attachment, select the "go advanced" button at the bottom right of the post window.
Then scroll down to the "Manage Attachment" which will open another window and enable you to select the file on your PC and upload.
