If just jumping to 45' 90' and 180' angles you should be able to specify those using just SERVO command, setting the 'Position' to the appropriate values.I am trying to write simple code to move servo motor to 45' 90' 180 using the flow chart.
can I do this using the servo command only or do I need to use variable as well - and if so why.
