We are working on a project using a 28 X 2 micro, but presently only utilizing four of the pins.
What is the rule concerning leaving the others floating? Does that lead to erratic behavior? If so what is the proper correction?
Thanks, Gramps
Never leave an input pin floating
A floating input typically picks up 50/60 Hz hum unreliably
Either set unused pins to output, or provide pull-up or pull down resistors.
Having said all that - receiving unknown signals on an input might not cause a problem in real life - but why take the risk? (confession - I leave spare/forgotten inputs floating most of the time and seem to get away with it)
Leaving the MCLR pin floating would be a really bad idea - and will cause problems for most PIC or PICAXE chips. Provide 10K Ohm pullup for MCLR pin to avoid problems
I ALWAYS provide 10K Ohms resistor MCLR to Vcc whatever the circumstances (or I may risk 100K Ohms if low current consumption is important)
If you're using a 28X2 or 40X2 PICAXE, it is important to wire it up as specified in Manual 1 "Getting Started" at around page 34. It specifies a 4.7k ohm pull-up on the reset pin.
Hi All Just a quick one I have a 20x2 on a board I have made for it for a project I am playing with I make up my own breadboard adapters for the down load side of things when the adaptor is attached the board runs as expected, but when disconnected from the 3 header pins the board does not run...
