JayAuckland
I am building a small lighting controller/fader system for a friend's miniature model theatre, using the adc on 10 x 08m2 chips to read 10 'channel' slider pot faders and outputting/buffering the pwm from each pic through two paralleled darlington pair inputs (ULN2803).
The paralleled outputs of the darlington pairs for each channel go via a header and very short ribbon cable to 'mimic' leds beside each channel's fader. The output of the darlingtons also go to a d-sub connector to feed the outputs via a 1metre ribbon cable to the theatre's LED 'spotlights'.
A master fader 08m2 chip operates much the same way but also calculates a 0 - 100% value from the adc and serial outputs this down a common bus to all the channel pics where it is used to modify the adc-to-pwm value. It has a mimic LED but the pwm is not used for anything else... it does not go to the ribbon cable.
Channel fader code:
Other 08m2 inputs are reserved for functions to be added at a later date such as on/off switching and automatic fade up and down. For now those inputs are held low.
The paralleled outputs of each channel's darlingtons feed mimic LEDs on the control panel (via very short ribbon cables and headers) and will soon also feed the LEDs in the theatre 'spotlights' via a 15pin d-sub connector and about a metre of ribbon cable.
The controller unit itself works just fine with good output response to the channel and master faders and steady mimic LEDS.
PROBLEM:
When I connect the 1 metre ribbon cable (without anything connected at the other end at this stage) some of the mimic LEDs start to flicker to full brightness slightly, sporadically and apparently randomly. The flickering on each channel seems to be independent of the flickering on any other channels. And it becomes slightly more evident as more faders are moved 'up' away from zero level).
Physical layout: the channels with the worst flicker are furthest down the serial/percentage common line and nearest (electrically and physically) the power supply - which is stripped out of a standard +12v domestic switchmode plug-in psu. +12v powers the mimic and (eventually) theatre LEDs, as well as the pics via a simple 7805-&-capacitors +5v regulator circuit. The master fader (not attached to the ribbon and furthest away from the psu) does not flicker, nor do the four channel mimics nearest to it.
Does anyone have any suggestions on how to work out what is going wrong here? Inductance in ribbon cable? RF interference? Unit and case are earthed.
(This is my first seriously grunty PICAXE project so pretty much everything I am doing is at the very limit of my knowledge so far!)
Jay
Channel fader code:
setfreq m4
disconnect
pwmOut 2, 60, 0
Poll:
serin 5, N4800_8,("MF"),b6 'input master percentage into b6
ReadAdc 4, b2 'read channel fader level into b2
b7=b2*b6/100 'apply master percentage to fader level, store in b7
pwmduty 2, b7
goto poll
PROBLEM:
Jay
