Flashing lights for desk ornament based on 18M2+
DamonHD
#1
Hi
I promised my dad an ornament for this desk flashing 7 LEDs (6 in a ring with one in the centre) ... oh about 35 years ago! Yes, really.
Well today, with some consultancy from my 7yo daughter, I built it on breadboard. I will transfer it to strip-board in time for my dad's 70th!
Code is here:
https://sourceforge.net/p/picaxeplay/code/18/tree/trunk/7LEDs/18M2.bas
I can link to pics/videos if anyone is interested.
Rgds
Damon
#3
Yes, please post the circuit diagram and any photots on this forum and avoid the links to external site. (All too often I find broken links where folks link to their wown website with all good intentions but eventually after a few years the external website dissapears.
Well done on providing comemnts and use of indenting for looping and test structures :)
Here is the code to save folks going externally:
; n18M2.bas    234 lines (203 with data), 6.4 kB
; Damon Hart-Davis licenses this file to you
; under the Apache Licence, Version 2.0 (the "Licence");
; you may not use this file except in compliance
; with the Licence. You may obtain a copy of the Licence at
; http://www.apache.org/licenses/LICENSE-2.0
; Unless required by applicable law or agreed to in writing,
; software distributed under the Licence is distributed on an
; "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY
; KIND, either express or implied. See the Licence for the
; specific language governing permissions and limitations
; under the Licence.
; Author(s) / Copyright (c): Damon Hart-Davis 2013
; Flashing 7 LEDs, a red/green bi-colour in the centre; 6 surrounding it in a circle.
; Bi-colour LED between B.3 and B.6 outputs (via 330R+).
; All other B.0 to B.7 outputs driving LEDs (connected to ground via 330R+) in clockwise order around the circle.
#picaxe 18m2 ; 18M2+ device.
#no_data ; Not using the EEPROM.
dirsB = %11111111 ; All outputs.
symbol LED_BI1_RED_C = B.3 ; Bi-colour LED red cathode (short leg), green anode.
symbol LED_BI1_RED_A = B.6 ; Bi-colour LED red anode (long leg), green cathode.
; C.0: LDR light sensor (ADC input); higher voltage indicates more ambient light.
; Should be pulled low externally whether LDR used or not, so can be left as input or set to low output.
symbol INPUT_LDR = C.0
; Light level (0 is dark, 255 is light).
symbol ambientLighting = B24
readadc INPUT_LDR, ambientLighting ; Take initial reading.
#rem
testPWM:
	pinsB = $ff ; Everything on.
	gosub centreRedSet
	gosub pauseAndPWMLeds1s
	toggle LED_BI1_RED_C, LED_BI1_RED_A
	goto testPWM
#endrem
; Speed (and possibly brightness) settings.
symbol MAX_SPEED = 4
symbol MIN_SPEED = 0
symbol speed = B25 ; 0 is slowest (can be used with nap).
symbol randWord = W13 ; Random number store
symbol randB1 = B26
symbol randB2 = B27
; Initialise with bits from the internal temperature sensor.
readinternaltemp IT_RAW_L, 0, randWord
; Warm up with some spins...
	for speed = MIN_SPEED to MAX_SPEED
    	    gosub spinCW
    	    gosub spinCW
    	    gosub spinCCW
    	    gosub spinCCW
	next
	sleep 1
mainloop:
    W0 = ambientLighting * MAX_SPEED / 255
    speed = W0
    ; Maybe do some spinning...
    do while randB1 >= $40 ; 0 or more times, typically 2 or 3...
        random randWord
        if randB2 >= $80 then
            gosub spinCW
            gosub spinCCW
    random randWord
    ; More likely to turn LEDs off and sleep here as ambient lighting falls.
    if ambientLighting < randB1 then
        pinsB = 0 ; All off...
        sleep 1
        B12 = 255 - ambientLighting min 1
    ; Do some flashing...
    gosub briefRandomRound
    sleep 1
    gosub reseed
    goto mainloop
; Stir a little entropy into the pool!
reseed:
    readinternaltemp IT_RAW_L, 0, W0
    randWord = randWord ^ W0
    random randWord
    randWord = randWord ^ time
    random randWord
; Pause for *nominally* 1s, matching LED output to ambient lighting.
; Destroys B11, B12, B13, B14, B15.
pauseAndPWMLeds1s:
    B12 = 100
; Pause in B12 units of *nominally* 10ms, matching LED output to ambient lighting.
; Destroys B11, B13, B14, B15.
pauseAndPWMLeds:
    B11 = pinsB ; Capture extant LED state.
    ; Software PWM on nominal 10ms cycle.
    B14 = ambientLighting / 25 min 1 max 10 ; On time: never 0.
    B15 = 10 - B14 min 1; Off time: nominally can be zero (for max brightness).
    for B13 = 1 to B12
       ; Aim for LED duty cycle to go down with the ambient light level.
       pause B14
       pinsB = 0 ; Turn all LEDs off.
       pause B15
       pinsB = B11 ; Restore state of LEDs.
    next
; Pauses in inverse proportion to speed and may adjust brightness of LEDs to match (software PWM).
; Attempts to conserve energy too.
; Destroys B10, B11, B12, B13, B14, B15
pauseToMatchSpeed:
    B10 = MAX_SPEED - speed ; B10 is pause time on 'nap' (log) scale.
    B12 = 1
    if B10 > 0 then : for B13 = 1 to B10 : B12 = B12 + B12 : next : endif ; B12 is pause time on (linear) scale.
; Spin clockwise at specified speed.
spinCW:
    pinsB = 0; All off...
    gosub centreRedSet
    high B.0
    gosub pauseToMatchSpeed
    high B.1
        low B.0
    high B.2
        low B.1
    high B.4
        low B.2
    high B.5
        low B.4
    high B.7
        low B.5
        low B.7
; Spin counter-clockwise at specified speed.
spinCCW:
    gosub centreGreenSet
    high B.7
    high B.5
        low B.7
    high B.4
        low B.5
    high B.2
        low B.4
    high B.1
        low B.2
    high B.0
        low B.1
        low B.0
; Do brief round of random flashing at current speed, with fewer and dimmer LEDs on with lower ambient lighting.
; Destroys B0 and others.
briefRandomRound:
    random randWord
    B0 = randB2 & $3f + 32; Between ~32 and 95 rounds...
    do while B0 > 0
        dec B0
        gosub allRandomSet
        if ambientLighting < $80 then
            random randWord
            pinsB = pinsB & randB1 ; For low light knock out about half the LEDs.
            if ambientLighting < $20 then
                pinsB = pinsB & time ; For very low light knock out about half of the remaining LEDs.
; Randomise all the LED states, as normal (B) outputs, using randB2.
allRandomSet:
    random randWord
    pinsB = randB2
; Turn the centre LED red.
centreRedSet:
    low LED_BI1_RED_C
    high LED_BI1_RED_A
centreGreenSet:
    high LED_BI1_RED_C
    low LED_BI1_RED_A
DamonHD
#4
Photos/videos (none spectacular) start here (follow the next> links for more):
http://gallery.hd.org/_c/electronic...ng-7-LED-desk-ornament-closeup-1-DHD.jpg.html
And I attach one of the stills.
Note that the thing next to the LEDs is a resistor array rather than the PICAXE which is elsewhere on the AXE091 board!
Rgds
Damon
PS. No circuit diagram for this: recipe is in the opening comments in the code.
PPS. My sites have been up and running more or less without interruption since about 1993, so here is a link to the snapshot on my site: http://d.hd.org/PICAXE/7LEDs/ (with a slightly tweaked .bas file, as it happens).
