Hi all,
I've finally got my first robot working. I've described it previously elsewhere but for those that don't know it's just a simple "car" that drives until it sees something in its path, then it decides which way to turn by looking both ways and turning towards the furthest distance. If both ways are too short then it reverses.
The code is here:
I wanted to add an led on pin2 that flashes whilst the robot is deciding which way to go or is reversing. So basically it needs to be off during the main loop and the nodanger sub, but on during any of the other sub-routines. I can do it with a simple on or off led using a high 2 at the start of "whichway" and then a low 2 at the start of "main" but I can't work out the flashing bit.
I could add this in between every line of code in the sub-routines but this would slow things right down and I thought that there must be an easier/smarter way?
I'm using the 28x1 project board.
Thanks
Paul
The code is here:
symbol dangerlevel=50 'how far away should things be before we react?
symbol turn=750 'this sets how much should be turned
symbol servo_turn= 300 'this sets for how long time we should wait for the servo to turn
symbol trig= 3 'define output pin for trigger pulse
symbol echo= 6 'define input pin for echo pulse
symbol range= w1 '16 bit word variable for range
servo 0, 150
wait 1
main: ' the main loop
pulsout trig,2 'produce 20uS trigger pulse (must be minimum of 10Us)
pulsin echo,1,range 'measures the range in 10uS steps
pause 10 'recahrge period after ranging completes
'now convert range to cm (divide by 5.8) or inches (divide by 14.8)
'as picaxe cannot use 5.8, multiply by 10 then divide by 58 instead
let range = range*10/58 ' multiply by 10 then divide by 58
debug range 'display range via debug command
if range > dangerlevel then
gosub nodanger 'if nothing ahead, drive forward
gosub whichway 'if obstacle ahead then decide which way is better
end if
goto main 'end of main loop, all others are sub-routines
nodanger: 'drive forward
high 4 : low 5 : high 6 : low 7
whichway:
gosub totalhalt 'first stop!
'look one way
gosub lturn 'look to one side
pause servo_turn ' wait for the servo to be finished turning
debug range
w2 = range
gosub totalhalt
'look the other way
gosub rturn 'to another side
pause servo_turn
debug range
w3 = range
gosub totalhalt
'decide which is the better way
if w2<dangerlevel and w3<dangerlevel then
gosub backwards
gosub decide
end if
decide:
if w2<w3 then
gosub body_lturn
gosub body_rturn
end if
rturn:
servo 0, 200
lturn:
servo 0, 100
body_lturn:
high 4 : low 5 : high 7 : low 6
pause turn : gosub totalhalt
body_rturn:
high 5 : low 4 : high 6 : low 7
totalhalt:
low 4 : low 5 : low 6 : low 7
servo 0, 150
pause servo_turn
backwards:
high 5 : low 4 : high 7 : low 6
pause turn
high 2
pause 150
low 2
pause 150
Thanks
Paul
