I have a project im in the middle of where I am recording the analogue value of 24 linear pots.
I am measuring the shape of an object as it changes so I need to record the value of my 24 pots to an EEPROM every say 4-8 seconds. This means sending 24 values + a time value to an EEPROM.
Once the EEPROM is full or the recording is finished I intend to send all the data to a computer to graph. I have managed to do this in realtime i.e. take readings, transmit, then graph, but I need to have the unit detached from a computer hence the need for an EEPROM.
I am thinking about using the IC 24LC256 EEPROM as it is the larger of two available from Jaycar NZ. I have never used an EEPROM chip before and don't quite understand how the memory works.
I studied the student exemplar project 'datalogger.pdf' in the help files but I find the use of symbols unusually hard to follow. I understand that this chip has 32Kb of memory (256 / 8 = 32) so how many records would I be able to make?
Also can anyone point me in the direction of a circuit diagram or basic code; I have done a search on the forum and understand that the readI2C, writeI2C commands are used but im a little unsure about te addressing. The exemplar project talks about getting 'data' from 'address' on 'page' of the EEPROM?
