Hey all,
Just joined here yesterday. I've used PICAXE microcontrollers at college but I've never actually done a whole project with one from scratch. This seems to be the right place to come and ask for help if I ever get stuck!
I've been doing my research, and basically what I'm trying to achieve is the rapid fire controller mod for the Xbox 360. I'm relatively comfortable with electronics and soldering, and I've already had my controllers in pieces many times before. Hopefully I won't need to post here many times for help, I'm more of a "Google about and work it out myself" person rather than "find the appropriate forum and get the members to do it all for me" type.
One initial question I do have is the best way for the programme to work.
I figured I could either use HIGH and LOW on an output pin, and repeat this while the trigger is held down. When I simulate this in the Programming Editor, however, this is very slow. Is it slowed down in the editor so that I can see what's going on? Or would it actually be this slow if I were to try it out?
I also found the PWMOUT command, which also seems appropriate. Which of the two would you recommend, or is there an easier way that I have overlooked? It just needs to power/unpower/power/unpower an output pin consecutively whilst the trigger is held down.
My USB cable is on order, and I have access to anything else I at college. Before you say, yes I know I could just buy a preprogrammed PICAXE with instructions off eBay, but I'm doing this for personal achievement rather than to actually use it.
Look forward to hearing any responses!
Charlie
Charlie
