I am trying to write my first program for a picaxe 40x2
I have 1 input button switch (momentary) connected to Pin C.1
I have 10 LED's connected to Pins #1 = D.6, #2 = D.7, #3 = B.0, #4 = B.1 , #5 = B.2, # 6 = B.3 , #7 = B.4 , #8 = B.5 , # 9 = B.6 and # 10 or (0) = B.7
I need the program to count how many times the button is pushed within a certain length of time (I have been using 5 seconds) and then turn on the appropriate
led ( the one that numerically corrresponds to the count) .
Like, if the button it pushed 3 times within the time interval, then led #3 turns on (pinB.0 goes high)
not haveing too much luck so far,,,
Below is the code I have written using the "Count" example in the manual as a base to work from.
I someone could point me in the right direction I would really appreciate it!
Thanks!
Randy
Thanks!
Randy
#picaxe 40x2
count C.1, 5000, w1 ; count pulses in 5secs
debug ; display value
if w1 = 1 then
high D.6
debug
elseif w1 = 2 then
high D.7
debug
elseif w1 = 3 then
high B.0
debug
elseif w1 = 4 then
high B.1
debug
elseif w1 = 5 then
high B.2
debug
elseif w1 = 6 then
high B.3
debug
elseif w1 = 7 then
high B.4
debug
elseif w1 = 8 then
high B.5
elseif w1 = 9 then
high B.6
debug
elseif w1 = 10 then
high B.7
debug
end if
wait 2
'turns off the leds so button can be used again
low D.6
low D.7
low B.0
low B.1
low B.2
low B.3
low B.4
low B.5
low B.6
low B.7
