I have been trying to build my single digit 7 segment DS18B20 temperature circuit on a stand alone bread board and have experienced a very strange problem...
Components:
PICAXE: 18F14K22 - 20X2
DS18B20 - temperature sensor (with 4.7K resistor on the data pin)
Kingsbright SC08 11EWA 7 segment display (using 1K8 resistors)
- see http://www.alldatasheet.com/datasheet-pdf/pdf/233140/KINGBRIGHT/SC08-11EWA.html for data sheet.
Breadboard
3xAA1.5v power supply
When I run the chip on the AXE-091 using the on-board 7 segment display and DS18B20 it works fine.
But when I put it on a bread board like (without the programming circuit)http://www.picaxe.orconhosting.net.nz/20m7segds.gif
I had the following problem/s.
The circuit runs for 3 seconds then switches off. When I disconnect the battery supply and try again sometimes it works, but only for 3 seconds.
I tried every combination that I could think of to try and isolate the problem.
I put the chip back on to the dev board it and worked fine.
I changed the code to:
and just tried to drive normal LEDS with 1.8k resistors on the breadboard. Sometimes the LEDs would light up and if they did it was only for 3 seconds.
I put power directly to the resistors feeding the LEDs (bypassing the chip) and they lit up fine. I even tried to only drive 1 LED in case I was trying to draw too much power through the PIC and it still did not work.
I did the same for the Kingsbright display and it lights up fine (run power directly through the feed resistors with no PICAXE involved).
I found that that when I put the chip back on the breadboard and did not press it in all the way the LEDs lit up sometimes, and if I 'wiggled' the chip up and down it slightly it would sometimes light up the LEDs without being pressed down all the way. So I though the breadboard may be defective. I tried a new breadboard and I had the same problem.
I kept on checking the chip on the dev board at every stage and it always works fine.
This is my first standalone PIC circuit and I am sure I am missing something obvious! But I have tried to follow a process of elimination to try and work it out for myself, but just can not work out what the fault might be....
(I have pulled the components from the breadboard - if a picture is needed I can put it back together and take one if it helps).
Components:
Breadboard
let dirsB=%11111111
let pinsb = %11111111
