thunderace7
Hi. I bought some IRF520/STP14NF10 transistors from the Picaxe store but, looking at the data sheet, I don't think they are logic level FETs. Can anyone confirm, please?
The ones I have like that make a convenient module. I snip off the IRF520 leaving as much of the pins as possible, and solder on IRL520 or equivalent. Pretty easy to do.I recently receive some MOSFET breakout boards, fitted with IRF520.
FWIW, I've found these logic level MOSFET modules to be useful: LL MOSFET modulesI recently receive some MOSFET breakout boards, fitted with IRF520.
in addition to prices shipping has significantly increased, seldom free.Most parts prices have doubled or better since Covid
Fitted with two D4184 (datasheet : Alpha & Omega semiconductor D4184), wired in parallel, each rated at 50A max, giving his best at VGS=10V. Rated at a lower current, 15A, that would probably do the job.FWIW, I've found these logic level MOSFET modules to be useful: LL MOSFET modules
The circuit diagram : Diagram. They probably added a second MOSFET to lower the rDS(on) at VGS=5V, although there is nothing to balance the current in between.... Probably OK to use a single D4184 FET at 15A ...
