Chris DeHut
Hi Group,
I have an application in mind that I think will work with PICAXE chips. Everything I need to do is going to require very high speed so I will have to overclock to 16MHz and or use the assembler function output.
I also need to have high speed communications between a PC (Windows) and the PICAXEs. While I could get 19200 Baud with the overclocking, I really believe I need much faster than that (at least my preliminary research is showing that).
So, faced with this, what are my options at this point.
I need high speed communications between several PICAXEs and a PC. The software on the PC is under my control (I am writing that software in VB6) so I have a bit of flexibility there. The PICs on the other hand I am stumped?
Chris
Chris
